habibparacha
Junior Member level 2
I want to design a Permanent magnet DC motor's Speed control circuit. The motor is 8.0Hp which means approx 6KW. I want to derive the motor with 48V DC supply. I want to select a suitable IGBT which will smoothly control the Motor's speed and able to handle the maximum motor current. Any suggestions will be helpful.
I am not able to find the suitable part. Is there any special way of searching a part according to your specifications. Is there any online tool that can help you out in finding the parts you require.
