naterg
Newbie level 2
I'm in need of a step-up IC for a constant voltage power supply for a battery-operated toy I'm making. I have the following specifications. Any suggestions or even references to possible sources for assistance or reading material would be greatly appreciated.
Requirements:
1. Must be powered from 3 alkaline cells and work with input as low as 2.7V; and
2. Must be capable of supplying at least 5.0V; and
3. Must be capable of continuously supplying at least 320mA; and
4. Must be easily sourced (currently available at Mouser or Digikey or sample easily obtainable by Joe-blow tinkerer); and
5. Must have shutdown mode that can be actuated with MCU; and
6. Typical supply current in shutdown mode must not exceed 50uA
Preferences (but not absolute requirements):
7. Output 5.5V
8. Through-hole
9. The fewer the required components, the better.
10. Cheap?
Thank you for your time and consideration.
Requirements:
7. Output 5.5V
8. Through-hole
10. Cheap?
