hiphei
Member level 2
Hello!
Been away again from here and some projects due to some health issues, but i'm starting again on one project..
However as i'm an old fart from relay era i have a question about eg. BTD441T -type loadswitch ic's.. As an example that ic has 20mOhm on resistance and 38V max. input voltage..
If I was to replace some 32A relay to save on pull current i think quick assesment showed me i should aim at singles value of mOhms (can one say like this in english..meaning going from tens to ones?!)
I'd need high side switch and initially thought getting p channel mosfets..however i'd need quite bunch of them to get any performance advantage and it'd be quite a hassle with discreets
Along came google search about pmic's and i learnt about eg. abovementioned ic..
I've checked the datasheet, but at least the one i found told nothing about can they be parallelled to lower the ohms (there are ic's even 1.3mOhm ones or so, but their max.voltages go too low and i'd need the higher max voltage and then the mOhm are high again..typical voltages i need would be less than about 32V maybe 35V in worst case conditions and currents between 20-30A)?
If there is no problem parallelling them, are there any precautions to do that (eg. separating the control with resistors or anything else)?
Just looking for some experience and rough guidelines here..
Best Regards,
hiphei
Best Regards,
hiphei
