Sony KDL-32EX400 ghosting problem
edincj
Newbie level 1
Newbie level 1
Good Morning.
i have a problem with ghosting on my lcd tv.
the ghostin is across the complete screen of about 2.5cm(1 inch) lower that the actual picture.
i also have black lines at the bottom of the sceeen of about 50mm(2 inches) wide.
i have repalced the t-con board but its still the same.
this looks like a vertical adjustment issue for some reason. i have been onto the service menu but have no idea what to look for.
please can someone help.
also if someone can help with a service manual. i would be eternally greatful.:-(
byronboy
Good Morning.
Hi.
Most ghosting type effects on lcd tvs tend to be caused by the lcd panel itself,especially if it uses a
samsung display panel.You have changed the t-con pcb,then the display panel is probably suspect.
Regards, Byronboy[ recently retired tv engineer]
classicbuff
Newbie level 2
Newbie level 2
Good Morning.
You can try eservice. , manualparadise.com or manualuniverse.com
