Simulation of the Phase locked loop dead-zone using Cadence Virtuoso and spectre
amsdesign
Member level 3
Hi I'm trying to simulate the dead-zone present in the phase frequency detector of a PLL. However, I get these waveforms
Here is the circuit diagram of the phase frequency detector. The FFs in my simulation have a reset that need to be set to LOW. So I'm using a NAND gate and Z is the output of the NAND gate.
However, for any amount of phase shift, I see ringing on the nodes. Why exactly is this happening?
You should correct the schematic for clarity, but I see that you are actually using a NAND gate in simulation.
There's apparently a problem with the reset timing of the DFF model, it seems to expect a longer signal duration. Adding some delay in the reset path should fix the issue.
Hi FvM,
Thank you for the solution. It worked now.
Here is the proper schematic:
However, there are still some problems.
Here are the specs for pulse generators A and B.
Period : 2us
Width: 1us
Rise/Fall : 50ns
UP is QA
If there is a delay of 1us between A and B, UP(QA) is able to capture the phase difference (after I added the delay block of 1us in the reset path)
Waveform:
However, for a smaller delay , say 500ns, and a delay block of 500ns in the reset path, I get this waveform. A 500ns phase difference captured on UP(QA), but I also get another pulse for 500 after that. The same goes for any phase delay less than 1us.
Why do I get this additional pulse on UP(QA)?
If have no idea about the speed of involved logic. What's the frequency of the oscillation in the initial post?
The same.
Period : 2us -->500Khz
Width: 1us
Rise/Fall : 50ns
No. I'm talking about the fast oscillation frequency which is most likely far above 100 MHz. It gives an idea of the required additional delay in the reset path.
I don't understand. Fast oscillation frequency?
It looks like the reset path is too fast to achieve a stable self-reset of the DFFs, resulting in a fast oscillation. Delaying the reset signal by the minimal reset pulse width (e.g. 10 ns) would help.
There may be also a problem with the DFF design. When the DFF comes out of reset, a static high level at the clock input must not be recognized as a new rising edge. You can check this in a separate simulation.
Yes, I did add a reset and for phase differences >1 uS the PFD generates the phase difference of the two signals.
But for a phase difference <1us I see multiple pulses with width equal to the phase difference being put out on QA. Why that peculiar behavior?
A delay of 500 ns or 1 us in the reset path is unsuitably high. Seeing still unwanted behaviour with a large delay suggests that the DFF isn't operating as expected.
I checked with a standard HC74 circuit, a statically high clock input won't retrigger after releasing the reset because a transmission gate disconnects the D input while C = 1. The standard PFD circuit can be expected to work correctly with HC74.
So, the problem is with the FF?
It seems so. As said, a simulation of the standalone DFF should clarify things.
