rayleighscattering
Newbie
So i have a resonator designed in HFSS. I am using the eigenmode analysis on it to get an answer. I then go to DrivenModal once I couple it to a transmission line, to get the scattering matrix. But in order to do this I take the mesh from the eigenmode results and import them into the DrivenModal model.
If I had more than one structure, would it be possible to import the mesh from multiple sources? Or how would I go about doing this?
Any help is appreciated as I am very lost as how to achieve this. Thank You!
The reason I am doing it this way is because the drivenmodal produces a mesh problem which results in non accurate results.
https://forum.ansys.com/discussion/39518/simulation-of-resonator/p1?new=1#
--- Updated ---
