Hamid.Kiumarsi
Full Member level 2
Suppose that I want to design inductors on a CMOS process with 12 metal layers.
To increase the quality factor, I am stacking M12 (12th metal) with M11 and M10 using lots of via-holes.
The problem is how to simulate this structure with EM solvers
Simulating the real case which has via-holes with real sizes is a time consuming simulation and sometimes it's impossible.
As a result many engineers resort to use a big via-hole with the same size as the metals (M12, M11 and M10 in this case).
However if big via-holes are used then the structure will not represent the actual inductor precisely.
In the real case via-holes cannot carry horizontal currents but if we assume that we have big via-holes
with the same size of metal lines, then solver will assume that they can carry also horizontal currents.
What do you suggest for this case?
