Note: This feature currently requires accessing the site using the built-in Safari browser.
Hello,All depend on your need and the applications you are targeting ? On which software are you working on ?
I would say in general, in the early stages of developement you will go with a basical mesh configuration and as far as your design is becoming mature (at the end) you will use fine mesh to secure the results.
You should always keep in mind where are located the critical areas of you design, for exemple if your are dealing with microstrip RF coupler or filter coupling effect are part of the desing so you have to be sure that the mesh always fit the complexity of your desing. Some areas can be more sensible to the mesh than others.
Thanks for the idea.Roughly speaking
You generally start with coarse meshing then you make it a bit finer then observe the difference.
If the difference is small so that means the main convergence has been obtained.
Iterative method is also valid here as well as in every RF problem.
Momentum mesh algorithm is really good for such cases. You can use default setting and enabled Edge Mesh, that's it. You can then try more mesh density and compare, but I don't expect relevant differences.matching circuit for PA in Keysight ADS.
Thanks for this.Momentum mesh algorithm is really good for such cases. You can use default setting and enabled Edge Mesh, that's it. You can then try more mesh density and compare, but I don't expect relevant differences.
But there is one detail where I have seen many PA macthing network simulation fail: port with at the transistor terminals. Make sure your port representing the transistor terminal has the same width as the transistor lead. In this case, it is wrong to just place the port on the edge because then the entire edge is the port.
See appnote here:
Dr. Mühlhaus Consulting & Software GmbH » Edge/Area pins in Momentum EM simulation
Your RF EDA solution partner since 1993muehlhaus.com
