signal integrity & emi emc
er_r_karthik
iam a beginer in pcb design & i want to know what does signal integrity, emi & emc are really mean. What are their effects in a pcb? can i have some clear documents about these terms in the web
havi
Member level 3
hai
see from www.ultracad.com for som articles about cross talk, emc , signal integration. it is very good site.
bye
Added after 27 seconds:
hai
bye
Rame
Full Member level 6
BANGALORE
Pcb Design made simple by Walter c Bossart will be the best book for Beginners.
Regards
Rame
prasannavenkatesh krishna
Junior Member level 1
India
Hi
To make it simple
SIGNAL INTEGRITY : Signal Integrity is how a system affects itself. Signal Integrity is the ability of a signal to generate correct responses in a circuit. A signal with good signal integrity has digital levels at required voltage levels at required times.
EMC : Electromagnetic Compatibility, interactions with the environment. It results from the antenna properties of transmission line ( such as cable, package pin or route).
power_abc
Newbie level 3
you may read some book about hign speed digital design
blackbird3
Newbie level 2
One of the best resources for signal integrity and emi/emc is the following text:
High-Speed Digital Design "a handbook of black magic" by Dr. Howard Johnson.
If you work with EEs who already have high-speed design experience, it is likely that one of them has this text. In that case, ask if you can borrow it. Otherwise, you can also check out Dr. Johnsons web site. It's very useful and you can submit questions directly to Dr. Johnson...
http://www.sigcon.com/
Hope this helps.
Antonios
Banned
Cairo
U can try this link
there are good book named
Signal Integrity - Simplified
By Eric Bogatin
Publisher : Prentice Hall PTR
Pub Date : September 15, 2003
ISBN : 0-13-066946-6
Pages : 608
electron_boy
Full Member level 3
Chennai, India
Signal Integrity Issues and PCB Design - Douglas Brooks is a good one for beginners. its available at edaboard.com
ahmad_abdulghany
San Jose, California, USA
Regards
Rame
Do you have an electronic copy of that book? If yes, please upload,
I'm not a PCB beginner :D but i need the book anyway..
Thanks,
Ahmad,
Pandiarajan01
Newbie level 2
India
hi
i want a coding for signal integrity effects in coplaner waveguide
---------- Post added at 09:45 ---------- Previous post was at 09:44 ----------
hi
i want a matlab coding for signal integrity effects in coplaner waveguide
info_req
Member level 5
Pakistan
Signal Integrity deals that how much healthy a signal is being received at the destination.
EMI lectomgnetic interferance. Interference of transmisiion sgnals with your system. or study of system with respect to antenna both transmission and reception properties.
EMC is elecromagnetic compatibility. working on system to get compatible with the environment. i.e. no signal transmission (such as magnetic filed cuopling) disturbs the surroundigs of you system.
