kikikrunch
Hi guys
Need a little help here as I'm new to VHDL. I kept getting the error of
This is my code. Any help would be very much appreciated.
ERROR:Xst:827 - "C:/Documents and Settings/Administrator/Desktop/temp/blink_led/simple_count.vhd" line 58: Signal count cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity simple_count is
Port ( clock : in STD_LOGIC;
enable : in STD_LOGIC;
dir: in STD_LOGIC;
reset: in STD_LOGIC;
leds : out STD_LOGIC_VECTOR (3 downto 0));
end simple_count;
architecture Behavioral of simple_count is
signal count: std_logic_vector (3 downto 0) := "0000";
signal clk_div: std_logic;
begin
clk_divider : process(clock)
variable clk_count: std_logic_vector(23 downto 0) := (others => '0');
begin
if clock'event and clock = '1' then
clk_count := clk_count+1;
clk_div <= clk_count(23);
end if;
end process;
process (clk_div)
variable reset_var: std_logic := '0';
variable dir_var: std_logic := '0';
begin
if reset='1' then
reset_var:='1';
elsif dir='1' then
dir_var:= not dir_var;
end if;
-- start of reset function
if (reset_var='1' and dir_var='1') then
count<="1111";
reset_var:='0';
elsif (reset_var='1' and dir_var='0') then
count<="0000";
reset_var:='0';
end if;
--end of reset function
if (clk_div='1' and clk_div'event) then
if (enable='0' and dir_var='0') then
count <= count + 1;
elsif enable='0' and dir_var='1' then
count <= count - 1;
end if;
end if;
end process;
leds <= count(3 downto 0);
end Behavioral;
