Register Log in
Schematic circuit plot from Cadence Virtuoso
Junus2012
Italy
Hello,
I am trying to print my circuit schematic view, the circuit is not that big, its like fully differential amplifier with biasing circuit.
I tried to print the schematic by using three methods but non of them is giving me a clear result that I can use the picturer in formal writing or presentation
method1. using export image
method2. using export HTML from ADEXL
method3. using "print" command
Do Cadence suggest to use third part software for plot ?
Thank you
Dominik Przyborowski
Advanced Member level 3
Norway
As long as you not taking care on drawing style, don't expect good looking diagrams.
For publishing is better to use vector drawing software (any which you are familiar) rather then configuring V-Schematic editor and redrawing schematics.
BTW CDNS of course does not recommend any 3rd party software, the most probably would propose export to HTML because it is fancy feature added by them in 6.17.
Junus2012
Italy
Dear Dominik
thank you for your reply
Indeed I am taking care in my drawing and I draw it in such away that I want to look like that in my writing report,
Also I am using the print of the schematic in vector file type eps,
even I used the HTML as I mentioned before,
the problem the MOS or any element in the circuits becoming small when I put in the writing slide or page.
redrawing the circuit again in different software is time-consuming
However, which softaware you recommend me as you said "For publishing is better to use vector drawing software (any which you are familiar) rather then configuring V-Schematic editor and redrawing schematics." ?
Thank you
Norway
You can disagree with my opinion, but after I saw some of your posted schematics my opinion is: no you don't.
In Virtuoso Schematic editor is possible to draw perfect diagrams, unfortunately 4σ of people doesn't care.
And since this point, please don't argue, simply treat my opinion as irrelevant.
There is a lot of software and the best one is this one which you are familiar with.
Some people would recommend MS Visio as it is MS product, provides good integration with Word, etc. Some other prefers Inkscape which is very nice open source multiplatform vector drawing soft. Very good, especially for it database is X-Fig. However, unexperienced person might feel bad with it interface (is like Emacs or Vi for Word user). I found good opinions about classic Xcircuit guy, also gEDA provides nice stuff. If you are linux user, kicad has been developed to something very well. There is a lot of various stuff and the best one is this which allows you to make work looking good and done quickly.
Junus2012
Italy
Thank you Dominik
I didn't mean to argue, but the circuit I draw for report I make it different.
See I have partentioned the circuit to make it more visible, but nothing from transistor you can read nor it is clear to see the difference between nmos or pmos,
may be there is option that make them saved bigger ?
Thank you for the sofware you mentioned, I am thinking to use Visio
By the way I just had a look on the Xcircuit guy, looks very good
sample picture
dick_freebird
Advanced Member level 5
USA
You need to pack the drawing tighter if you want to
resolve texts and small symbol details. The example
is much more sparse than it needs to be, what is the
value of all that "white space"?
If I'm making the library I like to make the symbol
features sensibly scaled. But other peoples' idea of
"sensible" is what it is.
I have looked at XCircuit, it's capable but demands
a complete unlearning of CAD-normal key and mouse
functions. It is indeed meant for "typesetting" and
clean drawing, and can be made to produce SPICE
netlists. Of course there's now a need to create the
whole set of used symbols, and to transcribe without
error....
I've been using xschem for my work, it's lean and the
key / mouse bindings are more "natural" for an ex-
Cadence-user. But again, libraries and transcription
are on you. Recent feature additions include ability to
plot from ngspice, by net selection (in the ngspice
native plot window) and a linkage to "gaw", a nice
little waveform viewer. The plotting has been fine as
far as I've used it.
sutapanaki
US
I usually use cadence Export with these settings. Produces decent images and if you zoom in for example in your power point presentation you can read device sizes even if circuit is big.
Junus2012
Italy
Output as HPGL file or Post Script file not eps.
I use HPGL.
Dear Pancho,
I tried both ps and eps they looks the same
I also tried HPGL, but the file I can't open it with inkscape
Thank you Suta
This method is good when I want to present my circuit from computer but actually to print or put it in document still has the same problem
pancho_hideboo
Real Homeless
Attached is a Microsoft Word document which imports HPGL in it.
Not same.
Convert ps to pdf.
Then export pdf as word or power point by using PDF-XChange Editor with registration.
sutapanaki
US
If by same problem you mean that you can't see the device parameters, it is because the circuit is too big. It saves what you have in the schematic.
Junus2012
Italy
Not same.
Convert ps to pdf.
Dear Pancho,
Thank you for your help
I downloaded the word file but it is not able to detect the HPGL file, means not visible to insert,
I also installed XnView image viewer and couldn't open it
I am kindly attaching you the file to see if it has a problem when you open it
View attachment tg.rar
Thank you suta, exactly my problem happen with bigger circuit, with small circuit the clearence of the circuit is acceptable
FvM
Super Moderator
Staff member
Bochum, Germany
You need to install the Microsoft HPGL import filter for word, review Microsoft help.
dick_freebird
USA
As a practical matter, document illustrations may come
out just fine with alt-PrScrn if you pre-zoom appropriately
and post-edit it in an image editor, provided you are on
a decent resolution monitor. If nothing else, Paint3D can
do the color map and crop functions.
Cadence's offered choices are lame and work-making. And
not improved in a decade or more.
Surprise, surprise.
Junus2012
Italy
Thank you friends for your help,
It all helped me to make decesion wather I go to use the Cadence plotter or third part software(like Xcircuit, Xschem, Visio), my supervisor also suggesting to buy the "Smart Draw".
By the way, I understand now there is a difference between ps, and eps file, but I dont see the setting of the ps prinView attachment .cdsplotinit.rarter in the cadence .cdsinitplot, please check this from the attachement
Toggle Sidebar
Design Fast
