[ARM] SAM3U4E KIT: code execution in SRAM
krunalwin
Newbie level 1
Newbie level 1
Hi all,
I do have SAM3U4E-KIT and was trying to run the program code from internal SRAM using sram.ld instead of flash.ld, but I can not find any option in device programming window(using J-link) of the atmel studio from where I can put the .elf in SRAM of the chip.
So kindly anyone here can help me to work it out on how to execute the whole code from internal SRAM instead of internal FLASH, because it is much often to write and erase the program in flash.
sram.ld & flash.ld are script files supplied with the KIT.
Thanks
