[SOLVED] Run a servomotor with a FPGA
mmp131316
Junior Member level 1
Hi all!
I have the following problem , I want to make a servomotor turn like i tell it to from the inputs(switches) of an FPGA for example if I have the number 30 i want the servo to turn to the 30 degrees position.I have done this on the arduino however on the fpga the servomotor does not go like i want it tics no matter how long or shor i make the pulse :-?
Here is a little arduino example and an image of the servo i want to control
FunnyRobotics: Arduino With Servo Motor
Thanks in advance:wink:
Providing the idea of what you want to do and waiting for someone else to provide you the code usually doesn't work.
Unless you are prepared to present your circuit specification and your code with specific questions I don't think you will get your solution.
Alex
You are right however i have managed to do it :-D
Thanks anyway :wink:
For the ones that are still trying to do this i'll post a link where they can find the verilog implementation and a link with the vhdl implementation.
fpga4fun.com - R/C Servos - here is the verilog implementation
Controlling an RC Servo with an FPGA - and this is the vhdl implementation.
Basically both represent the same thing the second however shows a way of controlling the servo from some buttons.
Cheers:wink:
Cheers:wink:
hi am work with FPGA using servo motor development, any one help me
