emontllo
Full Member level 4
Hello,
I need a shielded dual RJ45 8 pin connector with good (low impedance) contact between the shielding and the metallic conductive panel (EMI issues).
However the panel is mounted in a way, the typical connectors we are using do not make appropriate electric contact:
![pr2619014a.jpg pr2619014a.jpg](https://www.edaboard.com/data/attachments/8/8477-f5b7a10a090af3ef29d2211916174c91.jpg)
I need connectors that have a front tab like this:
(Picture from TE)
However I have not found the dual version, and it is very uncommon.
Does anyone know manufacturers of connectors like this, some references or any other solution? EMI gaskets are not a preferred option...
Thank you!
Ernest
![pr2619010c.jpg pr2619010c.jpg](https://www.edaboard.com/data/attachments/8/8478-5407d266e1c616beebc9043c5c499848.jpg)
Thank you!
Ernest
