RJ12 power supply. Howto connect UTP cable to terminals?
nunojpg
RJ12 power supply
I have a gsm modem with a RJ12 power supply input.
How can I connect that to terminal blocks?
The RJ12 is the easy part, I crimp a UTP cable. But how can then I connect the fragile UTP wire to the terminal blocks?
I can't find a robust solution:S
Regards,
Nuno
RJ12 power supply
Or change your terminal block to a female RJ12 or cut the RJ12 male to get the wires out to be connected to the terminal block which ever suits you the best. Cheers
Re: RJ12 power supply
How would you convert UTP cable to larger wire in a robust way? This is the adequate question.
Hope you are refing the cable given in the attached photo. As it is usually a single stranded and quite easy to handle. But unfortunately how can i express my practical knowledge on the web by writing?.....Hope you too can do it....just think how? You'll get answer. Cheers
    nunojpg
