RF receiver design concept
robismyname
Full Member level 6
Central Florida
rf receiver design saw filter
Im considering using a analog devices mixer (adl5350) in a RX design. I believe its either a single balanced or unbalanaced mixer (not sure). Im certain its not double balanced.
My LO freq range going into the Mixer LO port is: 2260MHz - 2343MHz
My IF freq coming out of the MIxer IF port is: 140 MHz
I am using a 140MHz IF Saw FIlter with BW of 1MHz
If this mixer is unbalanced will any of the harmonics/spurs show up within the passband of the 140MHz IF SAW Filter?
If this mixer is single balanced will any of the harmonics/spurs show up within the passband of the 140MHz IF SAW Filter?
Would it help the design any if I place an attenuator in front of the mixer? (see attachment)
concept of a rf receiver
An attenuator placed to the input of the mixer will improve IIP3 of the system, but will decrease Noise Figure.
Use the freeware program AppCad for system analysis:
http://www.hp.woodshot.com/
vfone said:
http://101science.com/RFSim99.exe
I have a RF input range of 2400MHz - 2483Mhz
I have a LO input range of 2260MHz - 2343Mhz
I have a ouput of 140MHz
WHat do I place into the Variable Frequency section?
What do I place into the Fixed Frequency Section?
What is the significance of the order box?
