can I directly connect max232 Tx pin to transmitter and receive the data at pic end using a receiver,or I need a Pic at PC end also.
To establish communications from a PIC to a PC using the RS-232 PORT on PC.
You must correctly connect a MAX232 to the PIC, then the RS-232 TX, RX and GND Pins can be connected to an RS-232 cable or to the PC RS-232 PORT.
PIC RS232
BigDog
I just want a one way communication from pc to pic,not the other way.I want to transmit data from pc serial port to a pic wirelessly.can this be achieved without using a pic on pc end.
What kind of RF transmitter do you plan to use? You can attach RF tx to you PC port over a MAX232 cct as well. You can send commands to RF device from a PC terminal tool (like hyperterminal etc.)I want to transmit data from pc serial port to a pic wirelessly
Emresel,
Brings up a good point. What type of RF TX/RX modules do you plan to use in your design?
You may only need a MAX232 between the TX module and the PC.
Most TX/RX modules have TTL I/O and do not require a MAX232 when connecting to a microcontroller.
BigDog
