sharkies
Member level 5
I have a simple regulated cascode.
I tried to get the gain of the loop transfer function, but this is what I get.
Am I simulating this wrong?
The transfer function should be coming out as a low-pass filter shape, but it's not.
I'm feeding a AC source and take the output right before the inductor
Also, I'm running the regulated cascode transistor(the aux amp) in subthreshold since the Vgs is only .2V , Is this Ok? when I check the output of the aux amp, it seems fine, It's only when I check the output at the inductor things seem screwed
