recovery time & removal time
manikanta.9332
Member level 3
Member level 3
Banglore
Hai all,
what is the difference between recovery time & removal time?
Where we are we are using these ?
What is the advantage of these both?
Thanks.......
Simple Understanding:
Recovery Time is same as Set up time but it is for Asynchronous Signal.
Recovery Time is same as Hold up time but it is for Asynchronous Signal.
For asynchronous control signals to flops, if they change close to active clock edge, the output of the flop is unknown (metastable). To avoid this scenario there is a recovery and a removal time that needs to be met to avoid this situation.
Removal timing check ensures that there is adequate time between an active clock edge and the release of an asynchronous control signals. It is like hold time for synchronous signal.
Recovery timing check ensures that there is a minimum amount of time between the asynchronous signal becoming inactive and the next active clock edge. It is similar to setup time for synchronous signals.
