reading parameters for Elaborate command in Synopsys DC
shahal
Member level 2
Does any one know how I can read in a file containg some parameter definitions for elaborating a design? I know I can do "elaboarate -param xxxx=abcd, ... "
However how can I do this if the parameters xxxx=abcd are listed in a file?
The good method is define all parameter in a single file and include it when using it.
else define parameter locally in file.
Hi Guys
Can you give me the syntax to include it, I am not sure I understand.
In a normal flow I would do something like this:
elaborate top -param "abc=123, \
def=567, \
ghi=890"
What would my syntax be if I had file called t1 which contained the following:
abc=123,
def=567,
ghi=890"
I have tried
elaborate top -file_parameter t1
and this doesnt seem to be working even if I have a -param option in that file.
Thanks for your help.
Shahal
