ifelix
Member level 1
Re: Radiation boundary problem in HFSS with antenna simulati
I've uploaded the file in attach. I've named it lamp.hfss.pdf so I can upload it. to open with HFSS remove the .pdf extensions and it works.
One big question: I've created a radiation boundary with the box of air as in figure.
I would know if when the software calculates the quantities for the far-field setup they are correct. In other words is this kind of box right for that model?
I'm not sure it is ok...maybe it would be better to place the antenna in the center of the big box(or a sphere of air in the same way) but the problem in that case is that I can't define the waveport INSIDE the air box or sphere.
In the case my model isn't right how can I do to put the antenna entirely in a box mantaining the waveport?
It's possible that the front face of the air box is too near to the antenna to cause wrong values for radiated quantities calculation?
Thanks in adv.
Added after 1 minutes:
sorry this is the file
Thanks in adv.
