suria3
Full Member level 5
Hi guys,
I'm designing a optical transceiver circuit which consists of Transimpedance Amplifier (TIA) and Limiting Amplifier (LA) which operates at the speed of 1.25Gbps. Currently I'm working on the layout for the design. I have a question here on doing layout for the high speed signal line. As attached in the diagram, TIA takes in current as the input and convert to voltage, whereby LA takes in the converted voltage to maximize the output swing. So, when it comes to the layout on the main signal part, what is the minimum distance (x) I need to keep between the two output terminal so that i can minimize the crosstalk and capacitance coupling issue. Feedback from the experienced designers are welcomed.
Thanks,
Suria
Thanks,
Suria
