STOIKOV
Full Member level 4
have a doubt, when refering to "breakout", its meaning is the routing from the pins of an IC to a distance over the package limits. Or it's about dimensions change in the width of a line?
Hard to say. Could you give more context? If you could post the sentence or the paragraph, where the word "breakout" is used in your case, that would help us answer.STOIKOV said:have a doubt, when refering to "breakout", its meaning is the routing from the pins of an IC to a distance over the package limits. Or it's about dimensions change in the width of a line?
