nirVaan
Junior Member level 3
hi guys
i have two questions
1. technically can a given voltage provide infinite number of current values provided the required resistance is available
for example can a voltage of 1 volt produce a current of 1000 Amperes if we are able to provide with a resistance of 1 mili ohms.
does this mean a value of one volt can actually produce a current that could kill a person
2. i have seen in books thats say when measuring resistance using a ohm meter to make sure your hands are not touching the leads specially when measuring high resistance resisters.
is this because when measuring a small resistance the current go through that resistance and not through the body (because the body resistance is so hing compired to the small resistance) but when measuring a large resistance sum current does go through the human body ?
does both hands neet to touch the two leads ,what if just one hand touchers?
thankz
[/GVideo]
thankz
[/GVideo]
