Question about broadband tee junction
sviodo
Member level 4
Member level 4
rf tee junction
I have to make a broadband tee junction however i encounter several problms tweakinng my idea of project. Not only did I use czebyshew transformer but also I was trying to increase bandwith by increasing number of transformer sections. Till now with a tiny sucess.
I was wondering if there is better idea to increase banwith or improved tee junction project :>
With Regards,
Sviodo
g86
Full Member level 4
Full Member level 4
On top of antenna :))
Re: tee junction
Maybe you need a very good tee. Otherwise multisectin czebyshew transformer is really a good choice. Can you please mention your requirements.
:!: :idea: :?:
With Regards,
Sviodo
Spasomat
Junior Member level 3
Hi Sviodo,
which bandwith at which frequency do you want to have?
What VSWR?
And what dividing ratio? 1:1?
Regards,
Spasomat
sviodo
Member level 4
Member level 4
My tee junction should operate at 12GHz with bandwidth as good as possible, S11 must be less than -20dB and of course it is 3dB power divider.
BTW it is microstrip sandwich structure.
Sviodo
g86
Full Member level 4
Full Member level 4
I think your method is good enough. have you chamfered the T junction? Multi section chebychev transformer can be used in both hoizontal or vertical arms. Sometimes the ripples may cross -20 dB due to some other subtrate parameters like dispersion, feed inductance. In that case binomial transfomer can be tried.
:!: :idea: :?:
Sviodo
