Pulse Width Modulator Improvements
CrystalMan
Newbie level 5
I have a little problem with a design which I have followed. I am novice at this really but have put a circuit board(Breadboard) together to send pulses through a water cell I have designed. My main problem is the frequency cycles being achieved, they are 20khz I believe, I want to achieve 1 to 10Mhz. Please could you advise me to the best ways forward. I have attached the diagram I followed
Maybe this is in the wrong section, please advise, the project is being done in order to help people in communities. I will discuss if answered!
Please check the datasheets of NE566 and LM741.. and read this manuel..
It helps you to determine how to get frequency
  • FM.pdf
    V
Do you think the trimming pots could be either removed or upgraded to support the desired frequencies? I appreciate your feedback thanks very much.
The NE566N only goes upto 1Mhz, I am looking to go between 1 and 10Mhz. I have 20K trimming pot, so that could work for the resistance aspect. The control voltage would be the way to go on a square wave. Do I even need the LM741? it does help on unwanted oscillations. It needs higher MHz tho!
MAX038 can achieve the desired frequency in pwm mode. 15% to 85% variable duty cycle
  • max038.pdf
That's it, by the looks of it, thx mate. Is there any schematics for this anywhere? I will look but if you know of a PWM schematic it would save time. Thx again it is definitely where I need to be this.
see the datasheet for the DADJ (duty cycle adjust voltage), at 0v the duty cycle is 50%.
