[SOLVED] problem with trunk routing in cadstar
puneethcp
Newbie level 6
Newbie level 6
hi...
some time in PR editor the Compose option is disable and not coming even if i restart the cadstar.
it is only enable after restarting the PC.
help me.
Sorry, cannot help you because I do not understand what your problem is.
Please explain it more, step by step and use the terms from in the program.
Explain what you are trying to do.
thankyou, actually the problem is i am not able to take the trunk routing sometimes, the problem gets solved when i restart the PC.
There will be a reason for it not allowing you to do it, either you are doing it wrong or there are design rules set that are preventing you and because you have it set to not allow errors it will not make one.
Have you got "allow errors" NOT ticked?
If so then tick it AND "online DRC".
P.S you do not say if it is the internal router or the external one. Same reply though.
