I need to simulate the impulse response of a microstrip in Ansys hfss so I am using the transient solution type. But i dont know how because when I create the wave port, as in frequency simulation, I get the error "The port has no terminals defined on it".
Thanks to all.
Camilo
Student and assistant Universidad de los Andes Colombia
It sounds like you need a driven terminal setup. When setting up your wave port, be sure to add terminals (or assign them manually HFSS->Excitations->Assign->Terminal...)
I assigned the terminals manually, but now I get the following error: "Too few conductors were found on port 1. There should be one conductor for each terminal, with one additional reference conductor. Unintentional contact between conductors may cause this error.". I dont know why because is a simple microstrip, I only have two conductors (Ground plane and the cooper of the line)
