Problem with initializing variables in VHDL
smileysam
Member level 4
1) whenebver i initialise the variabe , it gives a warning that its is not initialised and is ignored.
2) does not recognise signal or variables of type TIME
b<=a after 20ns; -- gives an error .. it cannot recognize "n";
3) Can someone explain RTL in a few lines .
Re: doubts in vhdl
Kindly try like this
b <= a after 20 ns;
Regards,
N.Muralidhara
doubts in vhdl
where do you originally declare the variables and signals ?
Re: doubts in vhdl
varibale declaration ..... after architecture and before the begin statement.
Re: doubts in vhdl
Hello,
apart from the syntax error (missing space with 20 ns) as you referred to RTL: This kind of delay statements are for simulation only, they can't be synthesized to hardware respectively used for register transfer level description.
Regards,
Frank
Re: doubts in vhdl
Hello,
Concerning point (1), variables can only be declared inside a process. It can not be intialized inside an architecture outside the process. If you want to declare something at the architecture level, use signals instead.
Re: doubts in vhdl
the signals should only be there...
as for the variables, they come before the begin keyword of a process statement (so they have to be declared inside a certain process)
P1: process (A)
variable X : .....;
begin
end process;
as for RTL, it means synthesizable code...or code that can be implemented actually with components....the delay statements, for example, aren't synthesizable!
doubts in vhdl
1- Variable must be declared and assigned a default value in the package file
2- Space between the time space value and the time unit is missing. (20 ns;)
3- Read more.
Re: doubts in vhdl
it can also be declared and defined inside a process statement
you don't have to use packages ;)
Re: doubts in vhdl
Hi Salma,
Yes you 're right but this depend on the tools used. I agree with you for DC but for modelsim packages are needed.
Re: doubts in vhdl
mmm
i don't get what you mean
it's all VHDL at the end :)
DC is for synthesis
Modelsim is for simulation
i don't see the relation!!!
Re: doubts in vhdl
mmm
DC is for synthesis
It's a bad exemple of tools. I should said modelsim and NCSim for simulation if you want (since simulable code don't imply that it is synthesisable).
VHDL is a language it's usage depend on the tools.
Suppose you have a synthesisable code. This imply that this code it is simulable. Unfortunately this is not always true is u r using Modelsim for simulation and DC for synthesis.
Re: doubts in vhdl
yah...i know that
but VHDL doesn't depend on the tool..it's just a way to describe the circuit...whatever the tool is...
i don't see the link of mentioning packages and their relation with the tools...it's irrelevant! that's just my point :) correct me if i'm wrong plz
doubts in vhdl
You're right. But, my experience with Modelsim 5.7 tough me that variables must be declared with their default value in the package file.
Re: doubts in vhdl
hehe
ok...modelsim can be annoying sometimes :D
doubts in vhdl
Variable will be declared and assigned in the package file
Re: doubts in vhdl
whenever an event has to be carried out at the network level....
say an addition/subtraction/division or any event....
high level abstractions are used to define the processor architecture...
this is known as register transfer level description...
it describes the operation of a system without reference to specific components....
regards
kazzam.....
