problem with cadence virtuoso layout
april1975
Member level 2
Member level 2
HELLO
I have problem with cadence virtuoso layout. my view of my layout is as picture!
How can I solve this problem? I have merged display.drf file, but problem exists!
pls hlp
Hello,
You can change the number of levels displayed by hitting Shift+f and then Ctrl+f to change it back.
If this bindkeys don't work go to Options => Display and change the Display levels to 32.
Hello lamoun
thanks for your help. it has been solved. but how i can activate shortkuts or bindkeys?
Hello,
These are some bindkey files I found over the internet.
You can use the following command in the cadence console: load "leBindKeys.il"
leBindKeys are for layout and schBindKeys are for the schematic.
You can also modify your .cdsinit file (or another one which I don't quite remember right now) so you don't have to load the bindkeys every time.
Here are the links:
You can also take a look here, at "load Bindkeys" section **broken link removed**
