problem with Cadence Virtuoso layout editor
coffeelox
Junior Member level 3
cadence virtuoso
I used Cadence Virtuoso layout editor and set display X/Y snap spacing to 0.01. However, while I tried to draw rectangular layers, I could not draw what I want. It seems that snap is much bigger than 0.01, so I either get huge rectangular or nothing. How can I set to draw any size or rectangular with 0.01 as step?
Thanks a lot,
erikl
Super Moderator
Staff member
Germany
snap spacing cadence layout
See this thread.
wpchan05
Full Member level 4
virtuoso layout editor
did u turn on the gravity mode?
coffeelox
virtuoso snap mode
Thanks a lot! yes, that's because my gravity mode is on... shamed...
coffeelox
gravity in cadence
I found now I can draw the shape anywhere, but I cannot move the shape anywhere. After I drew a rectangular, I only can move it to bigger snap spacing...
Ex:
X/Y snap spacing 0.02
minor spacing 0.01
major spacing 0.1
I can draw rectangular anywhere on the minor grid, but after drew, I only can move it on the grid spacing much larger than 0.01.
any idea?
erikl
Super Moderator
Staff member
Germany
minor major spacing cadence
minor spacing 0.01
major spacing 0.1
Exchange the X/Y snap spacing value against the minor spacing value! By this, you have always an access point between the grid points and in the centers of the grid.
coffeelox
cadence virtuoso layout editor linux
it doesn't work as well... please refer to the enclosed. Thanks a lot!
erikl
Super Moderator
Staff member
Germany
cadence layout setting
Try it with Gravity On !
BTW: With which tool did you create this movie?
coffeelox
virtuoso snap
I tried gravity on, similar result, I cannot move to where I want, and with gravity on, I even cannot draw where I want. any other idea? thanks a lot!
I use ubuntu, and the tool is provided called "recordmydesktop". nice tool...
erikl
Super Moderator
Staff member
Germany
virtuoso gravity mode
I use ubuntu, ...
Sorry, no more ideas. May be it's a pb. of your ubuntu window manager?
coffeelox
virtuoso snap spacing
but we are using ubuntu for all kinds of techs such as 0.13um, 90nm, 65nm, etc... there is no problem on others, only in 0.13um, is there any settings in system files such as display.drf, .cds.init?
BTW, which system are you using?
erikl
Super Moderator
Staff member
Germany
ubuntu cadence virtuoso
... or .cdsenv . But if so, you overrun this anyway with your new setting.
BTW: Did you try to set all these values a factor of 2 (or even an order of magnitude) less? What happens?
RHEL (RedHat) Linux 2.6.22.16-0.2-default with KWIN window manager.
In this context, s. also this thread.
