problem in ATF-34143 lna amplifier design
rajesh navagare
Newbie level 5
Newbie level 5
i have ATF-34143 .s2p file, .zap file, and footprint (pdf ) also, collected from avago site.. i designed 2 stage amplifier using 2 port s2p block and going to design layout for it.. but i m confused with it bcoz its having 4 pin ic where two sources are given.
if i assign component artwork as package SOT343 for s2p block, it gives me 4 pin IC layout but i m not sure where to use .zap file of ATF343.
i know how to unarchieve .zap file but dont know what to do next ...
.zap file is necessary while designing layout ?
*.zap is the old project archive format used in ADS2009 and earlier.
You can import in ADS with File > Unarchive if you want to see what is inside.
Or you can rename to *.zip and unpack with any program that can read *.zip format.
