rubdawg
inverted f antenna simulation in sonnet
I have been trying to simulate a printed -inverted F antenna using @DS and have had no luck in getting the correct setup. THe area of the PCB where the antenna is printedo is just a single layer board and it connects to the multilayer board. Is there a way to do this or am I taking the wron approach in this case. I have a prtotype of the actual antenna and I know it does resonate at 2.4GHZ and the VSWR I measured was aroun 1.7:1 but in simulations I have had no luck in getting anything close.
I can provide more info if need , but any help or insight would be of great thanks.
