Printed inverted F antenna simulations
rubdawg
Member level 1
Member level 1
inverted f antenna simulation in sonnet
I have been trying to simulate a printed -inverted F antenna using @DS and have had no luck in getting the correct setup. THe area of the PCB where the antenna is printedo is just a single layer board and it connects to the multilayer board. Is there a way to do this or am I taking the wron approach in this case. I have a prtotype of the actual antenna and I know it does resonate at 2.4GHZ and the VSWR I measured was aroun 1.7:1 but in simulations I have had no luck in getting anything close.
I can provide more info if need , but any help or insight would be of great thanks.
Try this link, the information is quite informative.
change h**p to h t t p;
inverted-f antenna simulation
Hi, I don't how you setup your simulation but for me, this is what I have done for PIFA using Zeland and Sonnet. Remove the ground under the PIFA. Set a thick "air" layer (1000 mm) between the dielectric and the bottom metal.
Finally, set the top and bottom metal to free space.
Check out the Sonnet Forum under its Knowledge base. You should see some discussion for simulating antenna with ground plane removed
www.sonnetusa.com
printed inverted-f antenna
try this can be help full
this these is very interesting
Regards
Hi My fiend
have U some detail from this these.
Regards
