MarcS said:Calculate the maximum instantaneous switching current, then look up the maximum voltage drop limit and the resistance per square of the metal layer. Then simply apply Ohm's law. Then add a generous safety factor.
As a final check, make sure that the wire is wide enough to keep the current below the maximum current density limit.
The hard part is determining the maximum current, which depends on you correctly assessing what transition will cause the maximum switching current. You can verify your results with power analysis tools (Apache, Sequence, Synopsys, ...)
