Power Factor Measurement using 18F4550
sghr220
Junior Member level 3
Hi all,
Found the following code while searching the subject. It uses two external interrupts (INT0 and INT1) for detecting the zero crossing of the voltage and current signals and timer 0 is loaded with a predetermined 10 us period, each time the timer overflows the code increment the variable "cnt_pf". The measured time difference is taken 5 times then averaged to achieve some kind of accuracy. The problem is upon simulation (Proteus) with a simple clock signals and time difference of 1 ms, the reading of the variable is wrong which i can't figure why!!! so any help is appreciated.
unsigned int cnt_pf = 0;
unsigned int sample[5];
unsigned int avg_pf;
unsigned int final_pf_cnt;
float count1;
short int i;
long tlong;
float angle;
 void Interrupt()
     if (TMR0IF_bit)
       TMR0IF_bit = 0;
       TMR0L = 0xD5;
       //Enter your code here
       cnt_pf++;
     }//  Timer0
     while(INT1IF_bit)// first zerocrossing found
       TMR0IE_bit = 1;// enables timer0 interrupt
       TMR0IF_bit = 0;// clear flag
       cnt_pf = 0;
       INT1IF_bit = 0;// clear flag for INT1
       break;
     while(INT0IF_bit)// second zerocrossing found
        TMR0IE_bit = 0; //disable timer0
        TMR0IF_bit = 0; // clear flag
        INT0IF_bit = 0;//clear flag for INT0
        i++;
        sample[i] = cnt_pf;
        avg_pf+=sample[i];
        if(i==5)
         i = 0;
         avg_pf/=5;
         final_pf_cnt = avg_pf;
        break;
That's assuming the current waveform isn't a pure sine or distorted which is not the case here. Not every load is switching.
I don't think that is the problem, however the variable "i" seems not to be initialized to any value.
How do you calculate the delay: final_pf_cnt * 10 us ?
What's your actual reading ?
The variable "i" is initialized in the main program this is just the ISR. yes, final_pF_cnt * 10 us is correct.
LaTeX Commands Quick-Menu:
