X
Xenon02
Hello !
I've been wondering if adding timer for my digital clock is a good idea.
I've added RTC to calculate the time and then every second the timer triggers the interrupt to update the time on my LCD screen and I wondered if it's a good idea.
Because there are other processes in the main and wondered if they are in the middle of executing the code and then it is interupted then if it's ok or not. I also added the timer to make sure that it will update every 1 second just thinking if I couldn't make it better but didn't want to add the update function into main while place because it would update with different time than constant 1 second. But also interupting the code that is executed right in the middle or anywhere else (for example uart I want to send 8 bytes and then interrupt occures and while he was sending second byte or third byte).
I mean I know that I have to remember about times etc. but wondered if it's a good idea because I couldn't find a better solution and DMA I guess, didn't know how to trigger update function.
