ravindra kalla
Junior Member level 2
i have to make a paralle arcdhitecture in which i am using processing element (this processing element is used to calculate sum of absolute difference of two matrics).in first case i have to calculate absolute difference of 18 matrcs so i need to use 9 processing element(two matrics in each element),but in second i need to calculate absolute differnce of 10 matrics so in this i need to use only 5 processing element.....one more case where i have to calculate absolute difference of 6 matrics so i need to use 3 processing element in this case.
so when i am using 9 processing element in paralle in my architecture then in second case 4 processing will remain idle in 3rd case 6 processing will remain idle.
so please suggest your solution so taht i can make my architecture in such away that i can utilise my hardware 100 percent in each case.
reply soon
thanx
reply soon
thanx
