Pls help on layout extraction
dshuang001
Newbie level 2
Hello
I got error messages when do extraction before LVS in IC5141:
error: Layer POLY is the common serial number source for connect layers:
POLY cap_poly cap_p12_term2.
info: If short location check is desired later on, check the saveInterconnect
statement for correctness:
Interconnect layer ptapc, pad_NPdio, ...... not saved.
And it concludes there are errors in the extract technology file.
But when i run it in IC44XX version use the same technology file, no problem occurs.
Please help me on it, thanks.
Sorry, I am using diva.
I am not sure if it is due to the difference between IC5141 and IC 44XX.
