HanneDE
Newbie
- Joined
- Nov 29, 2023
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 14
Hello,
I have an VHDL-Project on Quartus Prime Standard 22.1 which I want to test using Questa FPGA Starter 2021.
When running the testbench i have to Problem tha some signals are not shown to me.
Using the same testbench and entity on an windows PC lets me see the signals.
So i think this issue is releated to Questa.
When starting Questa from Quartus using Tools->Run Simulation Tool -> RTLSimulation
Quartus logs this error on the console
I can still start the simulation but maybe this is the reason for the signals to not appear. This error is not shown on the windows system. Does someone had this behavior before ?
Maybe i should add that i have delete an file named "liblzma.so.5" in the Quartus Installation path according to an forum entry from intel
OS is Fedora 38
# do Processor_run_msim_rtl_vhdl.do
# if {[file exists rtl_work]} {
# vdel -lib rtl_work -all
# ** Error (suppressible): (vdel-19) Failed to access library 'rtl_work' at "rtl_work".
# No such file or directory. (errno = ENOENT)
# ** Warning: (vdel-57) Library 'rtl_work' is missing or is not a valid QuestaSim library.
# ** Error: /home/hannes/intelFPGA/22.1std/questa_fse/linux_x86_64/vdel failed.
OS is Fedora 38
