If I place low voltage fet in high voltage well, will that device be considered as high voltage as well ?
For example:
Let's consider 5 volt to be high volt in 28nm TSMC process. and 1.2V to be low volt.
Now if I place 1.2V pmos in 5V NWELL, will the voltage on nets connected to that pmos also considered 5V nets and should I enforce 5V metal spacing DRC rules on those nets ?
I appreciate your guidance.
Not at all! The voltage tolerance of a MOSFET is mainly determined by its gate oxide thickness, not by its bulk environment.
High voltage MOSFETs need thicker gate oxide.
Not neccessarily. It depends on your PDK. Try putting a LV device in a HV well and run DRC. Place it next to devices that already occupy the well and make sure you add the proper pins and/or markers that may be needed.
