Pin property for symbol in DxDesigner and PADS Layout
Veronika
Member level 2
Member level 2
I am using DxDesigner and PADS Layout. I need to make a symbol for coaxial SMA jack, which has one signal pin and 4 GND pins.
In Layout I have 4 separate pins for GND but in Schematic I need to draw a symbol with one center (signal) pin and one outer (GND) pin.
So for GND I have one pin in Schematic but 4 pins in Layout.
How can I assign one pin in Schematic to all four pins in Layout??
Thank you in advance!
Hello Veronica,
You have to define this in the cell editor.
Open the cell in the cell editor and name the 4 gnd-pins the same, for example 2 or GND or whatever you prefer. The cel editor will show you the guides between the four pins. Now save the cell.
In the part editor open the pin mapping for the part, the four pins with the same name shows up as 1 pin. Map the two pins of the cell to the corresponding two pins of the symbol and save it.
succes.
Unfortunately, when I try to name these four pins the same in PCB Decal Editor, the PADS Layout does not allow me to do this and an error appears: "Alphanumeric name is already used."
I guess I am using another version of PADS...
What should I do?
Hi Veronica,
u can create symbol as u want in pads schematic but u can change pcb decal in layout.
just replace current pcb decal with two pads.
How can I replace decal with two pads if the footprint has one pad for signal and four pads for GND?? I cannot change the number of pads for the footprint of the component I am going to use...
