[PIC] pH Meter Value Conversion
Most likely, the numbers are hypothetical (wrongly calculated) values, at worst erroneous measurements, in any case they are wrong.
@FvM
What values are wrong ? Mine or hers ?
@KamW
Ok. What is the best method to design the pH Probe Interfacing Circuit using OpAmp ? What OpAmp sub-circuits do I need ?
pH probe gives 60 mV/pH
pH scale is from 0 to 14
0 is strong acid and 14 is alkaline
Now she said that she is using a pH probe Calibrator circuit and provided this circuit. Will this produce the voltages that she mentioned ?
measurement results are OK. your assumption in simulations are wrong.
I think you should read about pH electrodes. The best google show it is **broken link removed**
pH scale is theoretically from -inf to +inf. It is easy to get a pH of -1 (using conc HCl and water) or a pH of 15 (using conc KOH). What will be the pH of CCL4?
