Register Log in
PIC Digital power supply
preda
Member level 2
power supply pic16f873 picfun
Using 16f819 ADJ.V/A Display LCD 2x16
preda
Member level 2
Version2 Using PIC16F873
koky
Full Member level 2
Italy
without source code and with out description is not utility schematic
the first seem to a switching mode power supply, the second caotic scheme
the second downlad comprise also the first
wizpic
Advanced Member level 3
London
whats the source code wrote in
upload it give us a better idea
whats the maxium voltage out and current
your schematic is not to clear wheres the 2 pots on the front relate to on the schematic
wizpic
preda
Member level 2
source code
slavko
Member level 2
Hi, if I understand the scheme correctly you use a buck converter for regulation of output voltage and if I am right than my question is: How you tested this power supply? Did you only measured the output voltage with the voltage instrument or you have tested with different load connected to your power supply?
air
Member level 3
I am still confused on it. could you give a design digram. That perhaps make thing more clear. thanks.
preda
Member level 2
many friends can't know
kender
Stanford, SF Bay Peninsula, California, Earth, Sol
I couldn't find a buck converter there. There's no buck converter in the schematic. There are no power inductors in the photo. As far as I uderstand, it's a linear power supply (at least on the final stage), and the PIC is used to read the voltage and put it onto the LCD for the user.
But don't take my word for it, I might be wrong.
Toggle Sidebar
