PC to PIC 18F4550 USB interface
rikotech8
Hi every one!
How can I create a program that is interface by which PC and 18F4550 could communicate via USB (HID) communication. A simple program with three buttons(switch on/off leds) and one progress bar(for ADC signal). I mean, what is the program language that have direct access to USB port (may be C++,C#,Pascal or another program)? Just put me at the right direction, not to teach me on that language.something similar to this: Untitled.jpg
I assume you have looked at
if you download the MCHPFUSB framwork
there is plenty of sample code including a HID device custom demo
C:\Microchip Solutions v2012-04-03\USB\Device - HID - Custom Demos
this includes example PIC firmware USB device code and Visual C++ USB host code, e.g. using an Explorer 16 switching the LEDs ON/OFF and read a switch state. You can adapt this to suit your requirements.
it is fairly easy to implement VB.NET and C# code as well
hi,
I am dealing with a similar project connecting pc to card based on µcontroller via usb port i have problem making this connection please may anyone help?
thnks
hi,
thnks
Hi LillyMag,
What is "card based on µcontroller" ?
Try to describe your problem with more details, maybe someone can help you?
Best regards,
Peter
:wink:
I made my USB Device based on code this page.
Screen Shot of my device attached
hi,
the card is supposed to power control through vb.net interface data (time on/time off) must be sent via usb port to the card then the number of interchanges from on to off will be displayed on lcd display .
this is what my project is about hope that someone can help :) .
thanks
thanks for the reply,
the Isis simulation does not work because of the virtual usb driver installation ;i have already installed it but the same error is over and over displayed.
hi,
it's fine with isis simulation now i am facing problem with the vb.net interface i am not able yet to send data through usb to pic??
any suggestions?
