Register Log in
Parasitic inductor extraction using PEX in TSMC 180nm and running netlist through terminal.
Nancy12345
Junior Member level 1
I am doing parasitic inductor extraction using Calibre PEX, but inductors are unable to be mapped in calibre view since there is no cell present for parasitic inductor in TSMC 180 nm library. So simulation using config view is not giving correct results.
I have the pex netlist with extracted inductors, capacitors and resistors and I want to run it through terminal directly.
Can someone please tell me how to do that?
Thank you
nitishn5
Full Member level 5
Bangalore, India, India
In your config view, right-click the cell -> Set Cell View -> Specify Spice Source File
Here select your *.pex.netlist file.
This should simulate with your extracted netlist directly.
Nancy12345
Thank you so much for answering the question.
I did as you saiid and I am getting another error as"......./ ABC.pex.netlist" 134: Expression is missing a terminating quote character.". Should I edit the netlist to fix it?
timof
Advanced Member level 2
If you show us line 134, maybe we will be able to help you.
But your best bet is to ask application support form your vendor.
It's quite possible there are some fundamental problems with Calibre parasitic inductance extraction.
Toggle Sidebar
