- Joined
- Jan 22, 2008
- Messages
- 52,383
- Helped
- 14,746
- Reputation
- 29,774
- Reaction score
- 14,089
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 297,931
Some manufacturers are specifying 5V minmal supply voltage for UA741, but without any guaranteed input or output voltage range. As said in post #1, single supply operation is intended however, and thus UA741 clearly isn't suited. Any OP with a common mode including the negative supply and suitable out voltage range will work, e.g. LM358 and LM324. At low output voltages, the amplifier can't sink current, this is a basic restriction of single supply operation.
P.S.:
P.S.:
You previously told about 80 mV input rather than output voltage, buth both should work.the supply that i whould output is 80 mV
