dunv
After taped out,I found about 100M Hz noise apperaed at the PWM signal of my BUCK regulator .Ilet the PWM signal output pin to be floating,disconnected it with any external compnents,but It still be detected. I think maybe it is caused by the parasitic inductor and capacitor,or by the worse phase margin? Expected somebody give some suggestions.
Thank you very much
Thank you very much
