ngspice transfer function
ced
Newbie level 2
ngspice singular matrix
I am a ngspice newbie and I'd like to get a frequential transfer function of a Wien filter
as an exercise .
I'd like to plot V(3)/ISRC versus frequency .
Here is the .sch file I simulate :
Tranfer function
ISRC 1 0 AC 1
R1 1 2 1k
C1 2 3 1u
R2 3 0 1k
C2 3 0 1u
.AC DEC 10 1 10K
.END
Here is the result I get :
ngspice 1 -> run
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
Warning: Source isrc has no value, DC 0 assumed
Warning: singular matrix: check nodes 1 and 1
Note: starting dynamic Gmin stepping
Trying gmin = 1.0000E-03 Note: One successful Gmin step
Trying gmin = 1.0000E-04 Note: One successful Gmin step
Trying gmin = 1.0000E-05 Note: One successful Gmin step
Trying gmin = 1.0000E-06 Note: One successful Gmin step
Trying gmin = 1.0000E-07 Note: One successful Gmin step
Trying gmin = 1.0000E-08 Note: One successful Gmin step
Trying gmin = 1.0000E-09 Note: One successful Gmin step
Trying gmin = 1.0000E-10 Note: One successful Gmin step
Trying gmin = 1.0000E-11 Note: One successful Gmin step
Trying gmin = 1.0000E-12 Note: One successful Gmin step
Warning: Dynamic Gmin stepping failed
Note: starting source stepping
Supplies reduced to 0.0000% Warning: singular matrix: check nodes 1 and 1
Trying gmin = 1.0000E-02 Note: One successful Gmin step
Note: One successful source step
Supplies reduced to 0.1000% Warning: singular matrix: check nodes 1 and 1
Warning: source stepping failed
AC operating point failed -
Last Node Voltages
Node Last Voltage Previous Iter
1 0 0
2 0 0
3 0 0
doAnalyses: iteration limit reached
run simulation(s) aborted
Does someone has an idea about what's wrong in the scheme file ?
Thanks for your help,
ced
ced
Newbie level 2
There was no dc path between node 1 and ground .
Adding a very large resistor between both nodes solved the problem
Good Bye,
Cédric
sudheerkm
Member level 2
india
yes this how to cheat the dc bias problems for ac analys
you can do away with the resistor there it does not try to find bias point i suppose
s.jayaram88
Junior Member level 1
Bangalore, India
Alternatively to avoid this problem you can add high resistances to all the analog nodes in the netlist. This is a control option given in the .OPTIONS statement. For example if you would by default want a high resistance (say 1e12) on every node, use RSHUNT=1e12 within .OPTIONS
