mayang
Newbie level 6
Hi. I just wander on what supply I should pulled up to the resistor?
Here is the situation. In the LTM4705 IC from ADI, page 13 of its datasheet ( ). it says that ". A resistor can be pulled up to a particular supply voltage for monitoring." This is a Dual Output IC and the input voltage is 12V and it will regulate to 5 and 3.3 volts.
My question is what supply should pulled up the resistor? it is the 12V input or the 5V and 3.3V???
Because if I where to ask, I think I should pulled up the resistor to 5v and 3.3V since the purpose of PGOOD is to monitor the valid out voltage.
Am I right or maybe wrong?? hahahah
Thanks in advance.
Thanks in advance.
